Driving in snow
Hi folks,
I'm planning to replace my 2K A4 with an S4, I live in Canada, anyone with experience driving the S4 in snow? What's the ground clearance of the S4, can't find that figure anywhere. Do you end up plowing snow with the front end of the car before they clear the roads? My A4 was not too bad with a ground clearance of about 110mm. Is the sport differential noticeable on snow?
Thanks
Thanks
Had no issues in alaska last year, the ground clearance can be figured out by looking at the standard A4 ground clearance (which audi published) and subtracting the height difference between the S4 and A4 (which audi published(in the brochure for 2010 at least) - ground clearance is around 100 MM
I had no problems at all last year in New Hampshire. My '08 B7 A4 had just a bit more traction in snow (and much better seat heaters) but the S4 does just fine.
I live near Lake Tahoe in California and we had a pretty big snow year last year. I put some Blizzaks on mine and never had a problem. I never purposely took the car through anything deeper than 6 inches. I was worried about the Blizzaks because I'm used to studded tires but I think the Blizzaks did better. Plus I didn't have to listen to the metal spikes in dry conditions. Overall I think the S4 is a great snow car with the proper tires.
Hi folks,
Thanks
Thanks
The ESP/EDL can get confused (maybe it's just the brakes overheating) when trying to get going in 4"+ snow uphill. I've had it shutdown on me in different years on the same road. The fix is simple: turn the car off and back on. Just keep an eye out for the ABS light since your ABS goes out when the ESP or EDL does.
My A4 doesn't have ESP so it's a bit trickier to pass on 2 lane roads when driving in snow behind that car doing 25 in a 55 than if it did. However, it pushed bumper to bumper a new Beetle 1.8T through 6 inches of snow for 1/2 mile to a road that was plowed. The Beetle was floating on the snow. It was essentially a 2600 pound sled.
However since you mention the sport diff, this is mostly irrelevant as it seems you are in the market for a new one. I checked the Audi site a week ago or so and the dimensions on the A4 and S4 are the same. Ground clearance is not listed but if all else is equal, I think it would be fair to assume the same ground clearance.
My b7 seat heaters would get hot enough to cook an egg on, the ones in my b8 s4 just get warm. I will miss those seat heaters.
My 05 TT and 07 GTI seat heaters burn my ***, S4 seat heaters warm at best. However, they heat up very quickly.
Hi folks,
Thanks
Thanks
Bottom line is it's a sport sedan, not REALLY designed for heavy snow driving, IMHO, but it is very capable.
