Dropped on H&R OE
#12
#13
The winter tires made my car look "dropped" before I even changed the springs, so I think that's what we're seeing here.
I'll know more when I pick it up... and even more when I swap the summers back onto it... although those tires are slight larger as well at 265/35/19...
#14
I was told that an alignment isn't required after installing springs because nothing that affects alignment is really changed. That being said, I took my car in for its 15k service about a month after install and had the dealership troubleshoot the notorious low-speed shuddering issue that many B8 A4s have (not sure if this is common on B8 S4s as well) knowing that part of the troubleshooting procedure back then was to do an alignment (nowadays the known fix is to replace the power steering hose). So yes, I did get an alignment but I don't know if it's necessary.
#18
I'll get some better photos when I go get it in a few hours... or at least some more angles.
#19
However, think about in terms of lowering springs. You absolutely need an alignment because with the springs lowering the car, the camber and toe is now changed all around. If an alignment isnt done, youll wear out your tires faster than expected and add possibly more damage to parts.
#20
Wow this thing drives nice! It's definitely firmer, but not too bad... I'm not sure if my wife will like it, but I'm pretty darn happy. On the highway the car is super planted now, I really like it.
Here's a couple quick phone shots...
