DSG torque rating
Allegedly 406 lb-ft since it is used with the TDI also.
DL550 is rated for 550Nm (405.66 lb-ft).
There is also a higher rated version called DL750 (553.17 lb-ft).
By the way, there is kg-m (not used for automotive engine output), there is lb-ft, but there is no such measurement unit as kg-ft.
Um ok....
"By the way, there is kg-m (not used for automotive engine output), there is lb-ft, but there is no such measurement unit as kg-ft."
Not sure what you are referencing here?
I think you're mistaken. I'm well aware there is no such thing as kg-ft. :-)
uble1234
14
10-23-2020 08:07 PM
