Fault Code help
Hi, my 2013 S4 is having trouble starting and I need some guidance. I have a good battery but something is draining it. I'm able to jump start it and it will run fine for another Month then not start again. Here's the fault codes i'm getting.
CAN network gateway:
02256 - Quiescent current
03041 - Energy Management Active
01315 - Transmission Control Module (TCM)
00532 - Supply Voltage B+
Ignition authorization:
01330 - Central Control Module for Central Convenience (J393)
02812 - Steering Column Lock, supply voltage terminal 30
00446 - Function Limitation due to Under-Voltage
Central electronics:
Body/convenience system:
Driver's door:
Front passenger's door:
Rear left door:
Rear right door:
Driver's seat:
Heater & air conditioning:
Steering wheel:
Back-up camera:
Instrument cluster:
Parking brake:
10554390
329728
329984
ABS:
00473 - Control Module for Electric Park- / Hand Brake (J540)
01324 - Control Module for All Wheel Drive (J492)
Airbags:
13635840
9483264
Lane-change system:
114178
136194
731394
Radio:
Sound system:
Infotainment system:
03276 - Testing Management Software version
03367 - Supply Voltage Display Unit
Power steering:
18689 - Secondary Air Injection System Control 'A', Circuit Low
Structure-borne sound:
00002 - Transmission Control Unit
00004
00005
1179648
Driver's door:
Rear left door:
Rear right door:
Driver's seat:
Steering wheel:
Back-up camera:
Instrument cluster:
Parking brake:
10554390
329728
329984
ABS:
Airbags:
13635840
9483264
Lane-change system:
114178
136194
731394
Radio:
Sound system:
Power steering:
00004
00005
1179648
Hi Evan, I took it into an Audi Dealership today thinking it might be a battery problem. They did some testing and the battery is fine. The next step was they want me to come back for a 350 dollar voltage test. I recently installed a valved exhaust that uses the battery and a dash cam as well.
You probably know but are battery's have to be coded. If you don't know this it's going to sound crazy. So there is a bunch of different volt and amp battery's. That can go in our cars. So the car don't over charge and possibly cause a fire. You have to tell the car what battery if you don't. It will not charge it anywhere near full. If you have a friend witb a laptop that has the audi softwhere or any indy shop. But if you have a hardwired dashcam. That could be a drain and kill you batt also. I would not worry about any of the codes. To make sure there all just misreading due to low voltage. You could get the car running, clear codes , run for a while , check for codes. There won't be any idea bet doilers against door nails . Turning it off and back on befor the battery dies. But I'm pretty sure that between the 2 your going to find you problem. Good luck
WODT-Sanders
4.2 V8 Discussion
06-15-2019 07:46 PM
ceroberts75
03-10-2018 09:03 AM
