The great S4 tire air pressure controversy
#11
people in audizine said 39-40 is fine.
http://www.audizine.com/forum/showth...the-dealership
I think tech in Discount Tire forgot to go into MMI to reset the TPMS for you?
But, back to tire pressure. With me a bachelor, I generally have a light load while driving - not that I'm a light-weight or anything like that...
#13
No controversy to be had. Your manual sets out the exact pressures you should run F/R at various loads and tire sizes. Fill to correct pressure and save the setting in MMI.
#15
It's to improve the handling. Running slightly lower pressures on the rear reduces understeer as the front will have slightly improved grip for turn in while the rear will have slightly reduced grip and will rotate more.
#16
Thanks! This is the answer I was looking for. I assume this is because an A4/S4, though it has quattro, is still weighted like a FWD car; with a heavier front end. In contrast, a rear wheel drive car, like a BMW 3-series, is closer to 50-50 - with its rear while drive. So, you'd be more likely to put in the same air pressure in the front & rear tires in that car.
#17
#19
You havent asked if it was cold or hot pressure? I would go cold 39 psi as a long trip or hot day will raise it to 41 anyway and a very cold day will drop it down to 37 psi.
#20
I've experimented with this a little bit over the past few weeks. Started out with the OEM 19" summers on peeler wheels. Came from the dealer with 35 psi. Once I realized, I decided that was too low. Inflated to 41 psi. The right was pretty harsh. Right around that time, I switched to 18" OEM wheels with Dunlop 3D 225/45R18 winters. Wheels Works inflated them at 37 psi, which, again, I thought was low. Went to 41 psi, which was too harsh for the rough roads in the SF bay area. Lowered it to 39psi yesterday and drove 180 miles up to Lake Tahoe. Decided 39psi is the sweet spot for me.
I normally drive with 1-2 people in the car, rarely more.
