How to break in my S4
Okay fellas I have searched and read many things about breaking in these cars. I don't have mine yet, but when I do I want to be ready. This will be my first new car, except for GSXR 750 bike and I can tell you what I did.
There were two types of people. One, the guy that followed all manufacturer recommendations with break-in. Two, people who didn't. I rode with a couple hard core guys with a lot more experience then me and I trusted what they said. I'll never forget what they said and I lived by it. They told me that if I wanted my bike to run hard then break it in hard. They said to take the bike to redline in every gear at least twice and also engine brake and coast. They said it seats the valves quick and boosts compression. I did that to my bike and it did run hard as F__K!! I raced numerous stock GSRX 750's freeway and street and would always edge them out.
So I am leaning toward what I know. I don't know squat about Audi's though as this will be my first one. I would love to hear from guys that have done both. I'm leasing the car so long term I'm not worried about.
Thanks guys!
Thanks guys!
Good luck with running it hard brand new. The engine is not supposed to see sustained high speed runs for the first 500-600 miles. After that, you can run it hard. The cylinder walls and piston rings need to break-in properly, otherwise it can prematurely wear the bores. Trust me.
If you have read the posts on this forum about breaking in the car you know that the moto-man method is what has worked for many on these forums...A-world and A-zine.
http://www.mototuneusa.com/break_in_secrets.htm
When we hear about engines burning excessive oil it's because the engines were broken in soft.
I followed moto man / Dr GP method and I'm at 58,000 miles and have not needed to add a drop of oil.
I have many long hills around St Louis. I concentrated every day for the first 2 weeks on holding higher engine speeds while going down these hills. Then slowly accelerating up the hills in 2 and 3rd gears near but not quite at redline.
My engine purrs.
My engine purrs.
Banned
First and foremost, make sure the engine is up to normal operating temps. 2-3 times a day, NO MORE, (until you get to 1K miles) accelerate the car WOT to the red line, lift off the accelerator and allow the car to engine brake back to normal cruising rpms IN GEAR. I assure you that nothing unusual will occur once you reach the red line. In fact you can accelerate just shy of the red line if you are squeamish, but the car has already been run up to the red line at the factory. Do not do this drag race style from a dead stop. 1st, second or 3rd gear all work fine based on road condition and speed limits. WOT below the redline at will, followed by engine braking. No back to back WOT runs to the red line. After 1k miles, anything goes.
But why should you listen to me rather than Audi. Because Audi doesn't care if your car BURNS oil. They have arbitrarily set the standard for excessive oil consumption so high that they will almost never have a warranty claim. At 1 qt/1200 miles as being "within acceptable limits", you would add 10 qts of oil in 12k miles and still not be considered excessive. Pure Audio BS.
My engine purrs.
My engine purrs.
Simply put guys, I'm not going to do much explaining, BUT, what i'm saying is a factory guide to the break-in. The aluminum block needs a bed-in period. In Germany, they have had blocks prematurely fail due to high speed runs, something which in the US, does not occur much (no Autobahn like Germany), but it is mentioned, so the first 500-600 miles, you can drive it hard, just not for sustained periods of high speed runs. After this period, you can run it hard. I see these cars on a daily basis and deal with them all the time.
The point is, break-in should be done by varying the engine RPM a lot. Also the engine needs plenty acceleration and deceleration loading at varied RPM. One should try not run constant RPM during break-in.
Nobody is advocating sustained high speed runs, but following the factory recommendations isn't the answer either. Dr GP has it right. Get it warm, run full throttle to redline and engine brake back down a couple times a day, engine brake liberally and every chance you get, vary the RPMs, and feel free to take a few full throttle runs short of redline in between. It worked for me on this car and my previous one. Heck, I had it to redline within 20 minutes on my drive home from the dealership, and I'm almost at 20k miles on mine and have never had the oil level drop by any appreciable amount on the dipstick or MMI and have had no issues.
