When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Introducing AWE Tuning's Supercharger Cooling Solution: The ColdFront System.
Presenting the AWE Tuning Audi 3.0T ColdFront System. Designed in house at AWE Tuning, the ColdFront System is the solution for consistent and reliable performance for modified vehicles looking for maximum power and reliability.
The AWE Tuning ColdFront Heat Exchanger was developed to reduce high air intake temperatures found in supercharged engines. Designed in house at AWE Tuning, this should be a mandate for supercharged 3.0T engines looking to keep things consistent and reliable.
Each ColdFront Heat Exchanger is made to AWE Tuning’s specifications by Griffin Thermal Products. Griffin has a 30 year history of making performance aluminum heat exchangers, and makes all of their products in-house to ensure quality and optimum cooling performance.
The AWE Tuning ColdFront Reservoir is CNC Machined from 6061 Billet Aluminum and plumbed directly into the heat exchanger coolant system to increase supercharger coolant capacity. The increase in coolant capacity leads to lower coolant temperatures, in turn supporting lower air intake temperatures.
The AWE Tuning ColdFront Protection Screen was conceptualized to guard the ColdFront Heat Exchanger from road debris. The ColdFront Protection Screen guards the full face of the heat exchanger with durable stainless wire mesh and is surrounded by a stainless steel frame, protecting it against any small objects that may find their way past the vehicle’s grill. This keeps the heat exchanger fins free of damage, allowing them to perform with maximum efficiency.
When used as a complete cooling solution, the AWE Tuning ColdFront System has been shown to decrease IATs by 15F after 8 pulls separated by 30 Second Intervals on a B8 S4 equipped with GIAC/AWE Stage 2 Software in controlled ambient temperatures of 90F.
Coolant Temperature drops are also shown at a maximum of 24F during the same test as mentioned above.
After continuous full throttle acceleration tests using the stock heat exchanger, on our fourth run, power on a car equipped with the AWE Tuning B8 Stage 2 Performance Pulley Kit was down 12whp. With the ColdFront System in place, power loss was nearly non-existent after four runs in the same ambient conditions!
Find out more about the AWE Tuning ColdFront System, right here.
Interesting that you chose to have coolant actually recirculate through the reservoir instead of it simply acting as a fill point for the coolant. Any particular reason for this? Did you find it helped reduce temps by acting like an additional heat sink? Just curious.
AWE ColdFront™ Heat Exchanger compared to stock, courtesy of JRS Vehicle Customs & auto Design. Learn more about the AWE ColdFront™ System right this way.
It's time to secure your deal. Until December 3, receive the following discounts on AWE Audi products:
• 20% off MSRP on the AWE S-FLO Carbon Intake Suite for the Audi B8/8.5 S4/S5 3.0T.
• 20% off MSRP on AWE Intercooler Kits for the 2.7TT.
• 15% off MSRP on all other AWE Audi products.
Receive the following discounts on AWE Audi products:
Valid through participating AWE dealers and at AWE-Tuning.com. Get started right this way.
