S4 (B8 Platform) Discussion Discussion forum for the B8 Audi S4 produced from 2009-2016
Keyless entry stopped working? Fuse?
Old 06-18-2019, 03:21 PM
pbcsd's Avatar
Default Keyless entry stopped working? Fuse?
So out of the blue a week or so ago my keyless entry to my 2011 S4 stopped working. It's not the battery (won't work on either FOB).
Can use the key to unlock door and trunk by pressing the appropriate buttons, but won't automatically sense the key fob is near and open the doors.
Is there a Fuse for this I'm hoping that I can replace?
Old 06-18-2019, 04:54 PM
pbcsd's Avatar
Ran ODBEleven.
03285 error on door sensor. Assume they need to be replaced?
Old 06-19-2019, 03:49 AM
AForePlayin'03's Avatar
Is that the complete error? Or is there more to it which might give you a hint as to which sensor might be bad, like left or right, etc. Not sure if you googled the error, but I found this that might be helpful.
https://www.a5oc.com/threads/advance...problem.21211/
Old 06-19-2019, 05:00 AM
lmariorod's Avatar
Don't automatically start blaming sensors and replacing them. Make certain your car battery is up to snuff. Yes, door key sensors are the first to shut down when battery is weak. Yes, you can start the car because the power management reserves all power to start the car but slowly shuts down other minor accessories. Worth charging/changing the battery before replacing sensors.
https://www.audiworld.com/forums/aud...anded-2971566/
Old 06-19-2019, 07:19 AM
pbcsd's Avatar
Thanks guys. Anyway I can check the battery without going to dealer? Can't recall but I could swear I just replaced it a year or two ago.
Old 06-19-2019, 11:38 AM
pbcsd's Avatar
Checked with my dealer, replaced my battery April 2017 at 113k km, have 150k km now so shouldn't be the issue. Will recheck my ODB error code when I get home as I don't think it saves the last error code in the app without running it again.
Old 06-20-2019, 07:25 AM
pbcsd's Avatar
Originally Posted by DrGP
Replace the battery in the key fob first. The keyless entry wont work if that battery is low.
Pretty sure I just replaced them both in last few months but you're right.. Doesn't hurt to try!
Old 06-23-2019, 04:24 PM
pbcsd's Avatar
Definitely not the battery.
Old 08-08-2019, 04:55 PM
pbcsd's Avatar
Dealer confirmed its the driver side door at fault. Wanted $500 to replace it... 500??
Ordered the part off amazon for $30...will try to replace it myself.
Old 08-16-2019, 05:14 PM
pbcsd's Avatar
Replaced the door sensor today in about 15 minutes. Saved myself about cad$460.
Used this video, in German but figured it out.
The following 2 users liked this post by pbcsd:
Evan's Santorin S4 (08-18-2019), huskyz (08-17-2019)
Quick Reply: Keyless entry stopped working? Fuse?
