Looks like APR will use an Eaton TVS1740 for their blower upgrade...
I was a little surprised when I read this. Eaton never had any material on a 1740 blower, everyone assumed it would be the 1620 design that they never actually put into production. This should make for some impressive numbers, and leave room for a stage 3+ or stage 4 (upgraded internals) option.
I don't see it taking only 30 minutes unless it comes with all the factory components pre-installed (bypass valve, throttle body etc.). They designed it to be just like the OEM setup, so it should still be a fairly straightforward bolt-on.
http://m.cobaltss.net/forums/showthread.php?p=6463887
Copied from someone's post over on AZ
APR software as they will have to adjust bypass, timing, etc. given the additional boost... You could probably run Revo also since they seem to disable all the safety measures or set them very very high so they aren't triggered, but that would be dangerous/costly as a few have found out already...
shadyraven
10-25-2004 07:14 PM
dMang
09-02-2003 04:04 PM
