Manual tranny....smoothness.
#11
I don't have the problem either. BUT, you may want to try this. The B6 s4 6MT had a notchy 1/2 shift. It could be alleviated by putting pressure toward the left side of the shift gate while shifting 1/2. So instead of pulling the shift lever directly back, pull it back and toward the left. Can't guarantee it will work on the B8, but it did with the B6. Probably not the same trans. Alternatively, hesitating a a naosecond between 1/2 would also help. If this doesn't help, you may have a bad 1/2 synchro.Let us know if it helps.
Im wondering if Audi has something like this installed in their clutch lines?
#13
To the OP, I don't have SD either and find that my car shifts great, and it gets better as the miles accumulate. I think yours has some issues that the dealer will have to resolve.
#14
I played around on my way home last night to see if I could experience your issue... If I do not concentrate on matching the revs from 1-2 2-3 then it can be a rough transition. The revs drop so fast in this car I find that I need to shift faster than in my old S4 or my GTI. Makes it really hard to drive this car economically!
Maybe a short shifter would help the situation?
#15
Banned
Ok, this brings up something that everyone with BMW's experience. The 1st to 2nd shift is incredibly notchy and dull. Thats because since around '92ish BMW was putting in something called a CDV(Clutch Delay Valve). Theres a modification for it that opens the valve up and releases the flow of fluid so that the transition is much smoother and quicker.
#16
#18
Hope that it gets resolved to your satisfaction.
#19
#20
My shop foreman over at Classic AUdi is awesome. They are replacing my entire clutch instead of just doing the TSB. He told me that just doing the TSB does not fix what damage the faulty parts could have done to the pressure plate etc. I told him about squeeling brakes he told me that its normal as he owns an A4 same problem. He said yes they can be modified but the modification takes a lot of like from the brake pads and some life off the rotors. He said he could do it if I wanted. I told him I will try to bed in the brakes again. He laughed and said that almost what the modification does anyway. Its shaving down the pads and rotors lol. Anyway I will hear back today about where the clutch is coming from whether here at the warehouse or from Germany. If its here than I will get my car back next wed or thur.
