NO: DESPERATELY NEED HELP WITH TIMING CHAIN JOB!
Hey, I already posted this on s5 forum but since s4 is more or less the same, I take my chances here too. I really need help and Audi themselves wasn’t in much of a mood to help so yeah…..I have pulled the engine and dsg on 13’ s5 and split them to change the timing chains and tensioners. I pulled everything and replaced them with new parts. Did everything by the book and used the locking hardware for the timing correctly. However when I was done and went to turn the engine to see if everything was working correctly I stumbled upon a wall about three, 90 degrees turns later. Turned the engine in reverse a little bit and was able to turn it the same amount again but it locked up again. There is no spark plugs installed and there is no debris inside. I first suspected that the chain did not get the correct "fitment" on the tensioner side when tightening, like it was firm on the opposite side of the tensioner but I have removed and installed the cam adjusters, sprockets and the chains on both sides 3 times to be sure that there is no "slark/loose ends" on the wrong side of the tensioners. But no luck, engine still locks up when turning. In fact it has gotten worse, last time I did it, it would only turn one 90 degree turn and then lock up…..no workshop in my country would do the job for less than 13k so that’s why I have taken this job in my own hands. I wanna get it running again so bad )): thank you to those who took the time to read and my first language is not English either so excuse any mistakes or bad "wording"
!Engine code CCBA!
!Engine code CCBA!
thomshaug
07-24-2024 06:03 PM
ericchan81
07-10-2009 02:45 PM
viny
Audi allroad
09-27-2008 03:08 PM
