Oil light on 2012 S4
I have just about 1600 miles on my car now and the other day I started the car and the oil min. indicator light came on. According to the manual, you just have to add a quart, no big deal I guess. Maybe they didn't add enough factory oil? or is the motor consuming oil? This happen to anyone else?
As Goony said, check the level in MMI. You can get a dipstick from ECS at http://www.ecstuning.com/Audi-B8_S4-...ick/ES2070638/. You may want to add oil slowly and check with MMI versus dumping a whole quart in all at once. Having the oil a little below max is better than overfilling from what I've read.
Do you have a vag-com cable and VCDS software? If so, could you post your oil level info (before and after you add) in this thread:
https://www.audiworld.com/forums/sho....php?t=2818864
