parts manuals B8-S4
I already have that link, but it does not for example cover the NGY transmission, I am looking at the taper roller bearing spacers for the outer race for the front Differential, but the exploded view does not cover it. (see Pic). Crap I would be willing to buy it as online sellers for parts look at the same thing claiming to have the correct part because I give them the VIN number, but they are not allowed to take a snip it of the view to let me see exactly what they are selling me so I can confirm that I am buying exactly what I am looking for. It seems that everything covers the OB5 transmission and my vin says I have a NGY
ngy trans
ngy trans
I think the idea is that 19-2-20-21 have no replacement part. You need a new one of any of those, you're pulling it from a donor or buying a new transmission.
If you look at the service manual, 19 and 20 are called tapered roller bearing outer race, but to what roller bearing? One built into the differential?
The 0B5 is based on the 0B4, and if you look at the 0B4 page, there are part numbers for the 19 and 20, etc. But are they compatible? If you look back at the 0B5 page, you see most of the parts are 0B4 parts bin already.
You are correct I am doing what I call 100K maintenance and found that the front diff has not end play but side to side play indicating that the taper roller bearings are not quite shimmed correctly. I thought I might measure the gap and shim accordingly because I have to remove the diff, to replace a leaking drive shaft seal anyway. Trans and engine are out as you see, (exploded)
OMP
03-03-2009 09:34 PM
