Pirelli Cinturato P7
Anyone have the Pirelli Cinturato P7 tires come with there S4? Did a little reading on these tires, they are Pirelli's Green Performance approach to tires with low rolling resistance and a higher tread wear rating than the other stock tires formerly allocated to S4's. I did my first gas mileage check @ 600 miles and like the results so far....slightly over 20 mpg in town driving 100% of the time and about 20% aggressive driving. That's pretty good results for a new car with less than 1000 miles on it.
Highway mpg is pretty good... about 22-26 mpg depending on traffic. The tires are very quiet on smooth pavement.
When cornering, they feel like they stick like glue... but the Sports Diff is a factor, so it's hard to notice the tires' limits in normal driving.
I have the P7's and like them. The ride is on the rough side at 40psi which is to be expected I guess with 40 ratio. As for mileage,using cruise, I get an indicated 26 to 28 mpg (65-70mph) on my commute of some 25 miles. I use 93 octane Shell or BP.
I have 255/40/18 Bridgestone Potenza RE960 AS tires at 37 psi. Averaging actual 18.8 MPG for 31 MPH average speed from fill up. Computer MPG is 19.6 MPG (0.8 MPG high). ~12-16 mile commute, lots of stoplights.
Bruce
Bruce
sounds like you are getting pretty good gas mileage for you tire set up, considering your tires are slightly smaller in diameter and weigh appro. 4 lbs more per tire.
