rev. limiter
rev. limiter
my friend test drove my car last night, the schmuck went to red line & beyond a couple of times while driving, claiming it caught him off guard, specially on dynamic mode, the question is: why didn't the rev. limiter cut off power? also how bad could a couple of trips to 7200 rpm affect the engine?
Banned
Rev limiter was designed for exactly the situation you described. Saftey feature to PREVENT over revving and engine damage. It is set lower than what the engine can really safely tollerate. Shouldn't be a problem. But as previously posted, I would not want anyone doing it when the engine was cold. Actually, since you are still in the break in period, it probably did more good than harm.
I agree with what everyone here has said. However, you commented your friend went "beyond" redline. The only way that is possible is to downshift to a gear that's too low for the speed you are traveling at (like throwing it into 2nd at 80 MPH). The speed of the car will run the engine up over redline (the rev limiter won't help you).
If that happened, you could be in trouble depending on how far over your friend went (and how many times they did it).
actually, all 3 7200 rpm run he did were on first gear take off, no down shifting, the engine was about 20 min. running in 80 deg. evening, but i was surprised the rev. limiter didn't cut power @ 7200 rpm, in my 993 it did so just @ red line, also in my clk 55 & bmw 330i, does this mean the red line is set below the danger zone on this car? the car is 6mt by the way.
