View Poll Results: How do you drive your S-Tronic? Auto, Sport or Manual?
Auto
![](https://www.audiworld.com/forums/images/audiworld/polls/bar2-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar2.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar2-r.gif)
![](https://www.audiworld.com/forums/clear.gif)
11
31.43%
Sport
![](https://www.audiworld.com/forums/images/audiworld/polls/bar3-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar3.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar3-r.gif)
13
37.14%
Manual
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4-l.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4.gif)
![](https://www.audiworld.com/forums/images/audiworld/polls/bar4-r.gif)
11
31.43%
Voters: 35. You may not vote on this poll
S-Tronic - Auto, Sport or Manual?
When you are not in manual (M), you are in either D or S. You switch by pulling back on the shifter to where it says d/s. The shifter doesn't actually slide to a new position but just by rocking it to there it flips. You see the mode change on the instrument display. Switching to dynamic engages it too.
I heard it might have been different on pre-2013s
Effect is much more aggressive throttle and shifting, but its still completely automatic.
My current ride a 2010 S4 which I just sold is Stronic. Wife drives in in D auto. When I drive the cra which is 97% of the time it's always in full manual dynamic. I drive her in D dynamic each morning until it gets to operating temperature. Then she's driven in manual like I stole her. I have a company gas card so fuel economy is not a concern.
Regarding dynamic etc, not all cars have ADS that allows you to change the behavior of the car (suspension, steering, throttle). I don't have this, but I enabled some of it with VAGCOM. I drive in M mode 99% of the time.
How do you put it in Manual mode so you control shifts solely with the paddle shifter? Thanks.
Note that you can use the paddles at anytime, in D, S, or M mode. In D or S, though, the DSG will default back to its desired gearing after a few secs if you stop providing input. This can be helpful if you just want to downshift quickly for a pass or a sharp turn and then just let the DSG go back to higher gears after. I personally drive in M pretty much all the time. The car doesn't know when I'm about to turn, go up or down a big hill, whatever. I keep the RPMs around 2K or just under for cruising but the DSG will drop down to 1500 or so if you are in D mode which helps your MPGs a bit.
Hey KZEVO, you can move the shifter all the way down to S mode which gives you higher revs before shifting. Not sure if it affects throttle response. You can't move into paddle shift mode when in S, but you can still use the paddles and the car will revert back to its own desired gearing after a few secs with no paddle input from you.
