S Tronic Under Full Throttle
My S4 will not shift manually under full throttle. It shifts automatically in manual mode once it hits approx 6500 rpms but I can't get it to shift through manual mode. If I let off the gas a little, it will shift. I took an Audi mechanic out this morning to demonstrate. He is going to try another S4 to see if it is an issue specific to my car. Has anyone else experienced this? The mechanic also put my car on the computer but everything tested out OK
I can shift manually at any rpm if not fully throttled. The test I need is for someone to press pedal to metal in manual mode, do not let off the gas at all, then try to upshift with either paddle or shifter.
Under full throttle I can not shift manually at any rpm. Once the rpms reach 7000 in manual mode, it shifts automatically. No lie. The mechanic witnessed it also.
If it's technique then I would think this would have been a more prevalent topic on this forum. Otherwise, DSG owners have a light foot.
How do you floor it without engaging the switch? Are you saying there is a proper technique to it or are you saying that the gas pedal needs to be corrected?
Edit: that link isn't working. Click here instead: http://www.audizine.com/forum/showth...quot-mode-.-.-
I can confirm your results. I believe it is a software issue that all Stronics face. I had never noticed it before because when I go WOT I always let the Stronic shift for me. I dont really think its a problem though or at least not to me!
Check out this thread. I started it on Audizine raising the same question as you. Still not sure if I fully understand what's going on
I appreciate the help but I think we are talking about two different issues. Picture this scenario: I am at a drag strip. From a dead stop in manual mode, I press the gas to the floor. While in first I can't manually shift to second under full throttle at any rpm but once the rpms reach 7000, the transmission automatically shifts into second. Then I am in second gear trying to shift manually into third but it doesn't until once again it reaches 7000 rpms and shifts automatically. This happens for every gear. However if I lift off the gas a little, I can shift manually. It may be related to the gas pedal triggering a switch but I am not sure if there is a work around. It's as if the transmission swithces to automatic mode when accelerating under full throttle. It's terrible and I don't get the point of the DSG now.
now i'm confused as all hell. We need NWS4Guy to straighten things out.
Thanks for the reply. Unfortunately, I wish that I could upshift while under WOT. I thought the DSG would have offered the best of both worlds but I guess there is some compromise. I miss having a manual.
