Shift points
Shift points
I have been noticing lately that my car is feels pretty rough when up shifting. This is an S-Tronic automatic and I have only 600 miles on it.
It mostly happens when just smoothly accelarating, not when pushing it, and feels similar to when you let up on the clutch too soon on a manual when upshifting.
I don't recall having this feeling when I test drove 2 others and I'm just wondering if this is normal or something I should have looked at?
I guess my bottom line question is do others feel the shift points on their S4? This is my first coming from 4 A4's but I do not recall ever feeling them in an automatic like I do now.
Shouldn't be, but there was an Oct DSG update to the software that you should have gotten that solved this issue with the less than 5% who have DSG and complained about it.
I just got my car and think it was built in January 2010? Is there a way to check the SW version via VAG-COM to see if has been applied?
I'm not at all sure if this is same symptom / required c'measure that you might be experiencing, but FYI nonethless. When patch is installed I will try get the version no. and let you know how well it works. Car is fine otherwise, It's more a discomfort than car drivability problem while left as it is.
Is this happening only in dynamic mode? If it is, same here. The s/w update definitely improved the shifting smoothness in auto/comfort modes, so much so that shifting is virtually unnoticeable, but didn't rectify what you're describing in dynamic (at least for me anyway)
*edit* just read the post above, which gives better info :-)
What do I need to ask my service tech to check exactly (software version of what?)
The software that controls the behaviour of the S-Tronic 'box. If your car was built in Jan 2010, though, I would have thought that update would already have been included. From memory the update was offered around Oct/Nov last year (that's UK, mind)
Yes it was applied to all cars after Oct 30 (the date it was released) either in the factory, or at the dealership when someone was in for service. If it's having issues still, definitely mention it, and they might just do a reflash or schedule the mechatronics to be replaced.
Paldi
12-19-2004 05:53 PM
PoisenLoaf
10-12-2001 01:53 PM
