speedometer reading 160mph vs 200mph
#21
haha, guess it doesn't really matter, i use the digital display at all times other then when navigation is on maybe someone has a trick that i don't know about to use the digital speedometer when using navigation?!
..also i can say i was lucky enough to let the car loose twice and max it out.. pretty cool feeling.. seeing the digital display at that speed was pretty exciting, not even sure if i looked over at the speedometer.. but if i did, it would have still looked like i had room to go.. also i read somewhere you can order this car and request the governor to be moved to 174mph is that right?
makes senses them changing the speedometer to make it easier to see at lower speeds.. i usually keep my steering wheel at the lowest possible setting and seeing anything but the digital display is almost impossible anyways unless i duck my head a little..
#22
Alright great, I've tried to cycle through before but it never seemed to work for me, I'm gonna try it out when I leave the office tonight
#23
Banned
With the digitl readout, I never look at the speedo. Come to think of it, I rarely look at the digital display either.
#24
haha most likely never, considering the governor at 155, but was up there twice and can say the car handles almost better at those speeds then it does at 60mph, these cars are absolute machines, its quite incredible.. the only car i am considering but as a toy at some point is a 911(most likely will stick with audi for the DD either way).. but thats still a few years away.. for now the s4 definitely does the trick..
#25
So I purchased the car in Germany, brought the ECU back with me on leave to have it tuned (which took the speed limiter off). Had it over there for about four months with no limiter and can honestly say had it well over 160 many times, posted one of the runs on AZ and youtube. But yeah, used the digital speedo for that.
#29
#30
