Time to change the seats... thoughts?
#21
After getting nowhere with the dealer I purchased the car from, I reached out to my other local area Audi dealer (Chandler Audi in AZ)- who was absolutely awesome in providing help for what changing the seats would take. Total cost is high (expected) - but it is doable!
Given the cost, I'm going to explore my other options first (local auto upholstery company) and see where I get - and then come back to this if necessary.
For those also struggling with this issue, here are the parts necessary to make this happen (both seats):
Part #, Description, Qty Required, Price Per
8K0-881-905-A, Headrest, 2, $241
8K0-881-775-C, Padding, 1, $241
8K0-881-776-C, Padding, 1, $241
8K0-881-361-C, Padding, 2, $118
8K0-881-405-AA-WV2, Seat Cover, 2, $758
8K0-881-515-A, Frame-Back, 1, $671
8K0-881-516-A, Frame-Back, 1, $671
8K0-881-805-BK-WVZ, Cover, 1, $758
8K0-881-806-BK-WVZ, Cover, 1, $758
Total Parts: $5,578
Estimated Labor: around 12 hours @ $135/hr
For a grand total for both seats of around $7,500.
The biggest "risks" are potentially damaging seat heater coils since they are fragile; as well as coding issues when reprogramming seat control modules. Acceptable risks in my eyes at this point.
They also let me know that the bottom seat frames for the 2010 Audi A4 S-Line are identical - so the swap should be easier with those.
For now, I've build a seat cushion the length of the seat the exact width of the bottom to try and change the point at which my legs hit the side bolster. It "sort of" works. I think if I had the right density closed cell foam it may work - but I could only get open cell foam at my local fabric & upholstery store, which is still a bit too soft. I took a look at the Audi factory foam which is closed cell rubberized foam - which seems like what i need.
Sooo..... I suppose next steps are visiting the auto re-upholstrey company and/or searching the 'net for foam to build a new cushion. I may also study the part list more and see if I could rebuild just the seat bottom from the S-Line seats.
Total Parts: $5,578
#22
http://www.tushcush.com/carcush.html
#23
Really the best solution, by far the cheapest as well, is to have a reputable auto upholsterer remove some of the padding. It's very easy and even 1/4 inch can make a big difference, in the right spot.
#24
scott, i'm 6'2", 220 lb., and i had my problems with the bolster as well, this might sound too easy but it works and it's a saving of $7500 to change the seats, right after i settle in the seat, i move myself about 2" to the right, right leg half way on the right bolster, left leg totally away from the left bolster, it works amazingly for the left leg, just takes a little getting used to the pedal position(with a manual the pedals ars a little offset to the left of your feet), try it and see man, nothing to loose,cause everything else about the car is just right
zamalek
A6 (C7 Platform) Discussion
15
07-01-2016 03:20 PM
ScottAW
10-21-2001 04:52 PM
