Tire Question
Is there risk to stretching tires if I were to have summer/winter tires changed twice a year? I figure over the lease life I will have changed each 5-6 times.
Banned
Might actually be easier and as economically to buy some inexpensive winter /summer rims. Every time you mount/dismount tires you put your rims at risk for damage. Much less likely if you have a shop that uses the Hunter GSP equipment.
Mounting and balancing costs about $80 at my local tire shop using the Hunter system. Factoring in that you can get some decent replicas for under $1000 and then resell them for 1/2 their original cost if still in good condition. Most either go all season or summer tires (where the weather never gets bad) OR a dedicated summer /winter set of wheels and tires.
$1200-$1500 depending on how discriminating your tastes. The threads should be easy to search using the word tires or wheels.
Banned
I picked up 4 General G max AS 03 19" tires for $920, including tax, mounted and balanced with Hunter GSP sysem and disposal of old tires. You should do better with 18S.
Also, need to pick your brain with "Hard Break In" style if you don't mind via PM. The logic is sound but seems to be geared (pun intended) to a MT and want to make sure I get it right first time out with an AT.
Thanks EE
Banned
Are you including the wheels in this quote? I am talking both tires, wheels and hunter balancing is inclusive.
Thanks EE
Thanks EE
ichy076
S4 (B8 Platform) Discussion
15
09-27-2011 03:58 PM
Jason in Vancouver
Wheels & Tires Discussion
10-04-2003 07:03 AM
BoyTToy
03-04-2001 08:03 AM
