Unexpected features you're discovered during ownership
#71
You can vagcom aux heating and cooling, but the only thing it will do is run the fan on your car when it is turned off, not the heater or A/C. Still useful though when it's 100 degrees and your car is parked outside and you know you'll be coming back to it at a certain time, as you can set a timer to turn it on and at least circulate the air so it's only hot rather than uncomfortable.
#72
came back from a 3-day trip. while on cruise control, I found out the brake will automatically engage to maintain cruise speed. I noticed it on a downhill when speed kept picking up w/o pressing on accelerator. pretty sure it's not engine brake because rpm didn't rise when I felt the braking.
checked the manual and confirmed. it's called active brake intervention. LOL. guess I am falling behind all these fancy hi tech thingy.
#73
#74
A few random replies:
I didn't know about the grocery hooks until now, thanks for that!
The US cars do have hill assist but it isn't automatic - you have to engage the handbrake and it automatically disengages as you drive away.
The SD cards are awesome. The 2010 supports up to a 32GB SDHC card in each slot which can hold a lot of music (newer models may support larger cards).
Also one other feature is that the car gives you a warning/status message when your smart key battery starts to die. So you have plenty of time to replace it before you get stuck using the manual key. In one forum I read that they can be recharged but at least in my 2010 they definitely cannot - you need a new battery. Mine lasted almost 2 years.
#76
the hill assist is automatic on the 2012. I was recently at a parking garage on a steep incline and let go of the brake and it held it for a few sec before it lets go and then rolls back. I have tried to put on the parking brake and give it gas to see if it lets go automatically and o=it didn't, at least not on 2012's
#77
#80
