VAG COM fault code puzzle
Playing around with the Ross Tech cable tonight, and did an Auto scan to check any DTC faults. There was only one code and it has me puzzled. The only think I can think of is that the trial Sirius subscription just expired, hence the "tuner not enabled" code. The radio seems to work fine, and I could clear the code, but it would come back on the next scan. Any ideas?
Friday,01,October,2010,22:04:44:37844
VCDS Version: Release 10.6.1
Address 56: Radio Labels: 8Tx-035-1xx-56.clb
Control Module Part Number: 8T1 035 195 AD HW: 8T1 035 195 AD
Component and/or Version: Symph3 Sirius H06 0351
Software Coding: 240200020101870003D9070800
Work Shop Code: WSC 06325 000 00000
VCID: 79F2F2C649AB
1 Fault Found:
02635 - Tuner Not Enabled/Activated
000 - -
Freeze Frame:
Fault Status: 01100000
Fault Priority: 7
Fault Frequency: 1
Reset counter: 227
Mileage: 8583 km
Time Indication: 0
Date: 2010.10.01
Time: 21:58:57
VCID: 79F2F2C649AB
1 Fault Found:
000 - -
Freeze Frame:
Fault Priority: 7
Fault Frequency: 1
Reset counter: 227
Mileage: 8583 km
Time Indication: 0
Date: 2010.10.01
Time: 21:58:57
clear it and see if it comes back. I have seen a few odd codes that I have cleared and they never returned. My rule is that if they come back after clearing, then a problem.
Bruce
Bruce
This cade is described in the Ross-Tech Wiki as:
02635
From Ross-Tech Wiki
Jump to: navigation, search
Contents [hide]
1 02635 - Tuner Not Enabled/Activated
1.1 Possible Symptoms
1.2 Possible Causes
1.3 Special Notes
Possible Symptoms
Digital Satellite Tuner in Demo Mode
Possible Causes
Digital Satellite Tuner not enabled
XM/Sirus not activated
Special Notes
This fault code is only a note.
It is not a problem, just a note saying your satellite radio is not activated (which you already knew).
02635
From Ross-Tech Wiki
Contents [hide]
1.2 Possible Causes
1.3 Special Notes
Possible Symptoms
Possible Causes
Special Notes
absolutcq20v
02-14-2006 04:05 AM
Durrrrty Dufour
Mid Atlantic Discussion
11
07-22-2005 07:45 AM
nverfollow
13
06-18-2004 07:53 AM
