VAG Com Mirror Dipping
#11
Thats how it worked on my P+ 2011. About 1 out of every 4-6 times I need to lower the mirror a little bit after it moves back to normal position which is small PITA but well worth having the mirror dip in for parking cause most of the time I parallel park on the street and dont like curbing my tires. I dont leave it in center on heat icon because I dont know if it turns the side mirror heaters on or if its gotta be below a certain temp. I think it turns the heater on and I dont need to use it 24-7 while driving and dont want to break it
#12
#13
#15
You have to VAGCOM it for the 2010-12 to work. I have done it on my 11 S4 and you ave to have the right mirror selected on the drivers door for it to work. only problem I see is that it doesn't go back to the same location every time. sometimes it does, others it goes a little higher than it was previously and you have to move it back down. I agree about the back-up camera and not using regularly. but, when you are in the city like philly it is huge help because the back-up camera doesn't get that angle. For those in the WC area let's meet up sometime. We are setting up a meet in Philly for the AZ forum guys. But, for those of us that are close we should meet up sooner. or go to waterfest together?
Philly meet http://www.audizine.com/forum/showth...55#post7785455
#16
My P+ 2012 does this. Slightly, but it does move down. I wish it moved down further, as you can barely see the edge of the car with it at the current angle. Returning back to center seems a bit buggy as well. Seems to react similar to the intermittent(slow) backup camera I have.
Gr8White
08-26-2012 11:35 PM
transporter2004
31
04-02-2012 05:09 PM
dseag2
06-21-2010 03:14 PM
audibum
9
04-08-2004 10:01 PM
