Way uneven tire wear
#11
You're better off going to a shop that does "performance alignments" and they should charge anywhere from $75-$100 for a 4 wheel alignment. However, might be a good idea when its time for you to get new tires.
#12
I got my car aligned when it only had a few hundred miles. I don't trust any factory alignments for any car. Alignment report in link below.
https://www.audiworld.com/forums/sho...8#post24087288
Alignment tech said my alignment was pretty decent from the factory... However, i'm sure every car is different from the factory.
#13
#14
I wanted a more aggressive alignment than what the car came with...
I got slightly negative on front tow to make steering more responsive. Front camber cannot be adjusted.
On rears, got more negative camber dialed in.
#15
EDIT: I started a new thread up to discuss this to not hijack this one. Please take discussion of PSI discrepancy over here:
https://www.audiworld.com/forums/sho....php?t=2800088
About inflation pressure. My manual (2011 S4) has a table on page 279 that shows for a normal load (3 passengers) on 18" wheels it's 39 psi front and 35 psi back. A full load calls for 41 psi front and back.
BUT the sticker on the driver's side B pillar just says 41 psi front and back. No statement about load. No 39/35.
How should we resolve this discrepancy? Well, on that same page of the manual it says if the tire pressures in the manual don't agree with the B pillar, the B pillar always overrides.
So then, on 18" wheels it's 41 psi front and back.
I've tried 41 psi for a couple of weeks and found it to be a bit harsh, especially over expansion joints. I'm also worried about uneven tire wear in the middle of the tires. I dropped it back to 39/35 this morning and it feels a whole lot better.
What to do? What psi are people getting from the factory?
#17
Also not really sure what the expected life time of the summer performance tires should be. My other car (corvette) only gets 20-25K miles on a set of tires. I've been looking a Porsches recently and the dealer thought I should expect even less than that. The wear pattern that was originally described still sounds like an over inflation problem.
planux
07-22-2003 04:04 AM
PaulW
05-07-2003 02:40 PM
