Last edit by: IB Advertising
- Audi A4 B8 How to Replace Wheel Bearings<br>Step by step instructions for do-it-yourself repairs.
Wheel bearing failure
15k miles...at the dealership now because the right front wheel bearing needs replacement. I kept hearing a grinding noise with a small degree of vibration when making right turns at speed. Am I the first with this issue?
Anyone believe wheel spacers contributed to the failure?
First I have heard, but an improperly installed spaceer can absolutely cause the bearings to fail prematurely. If they are not centered properly or forged right, so that the balance is not perfect, it can put the shel out of balance, causing a lot of excessive force on the bearings with each revolution. With extremely thick spacers, it is moving the mass of the wheel farther from the bearing, increasing side loads on it, potentially shortening it's life, but this would need to be a pretty extreme sized spacer I would think.
I don't disagree with anything that's already been stated, but it does seem like very low miles to have been caused by the spacers. The extra load on the bearings shouldn't be that significant to cause an issue that early. It could also be a manufacturing issue with the particularly bearing given it's not a common failure item on B8's.
What brand of spacers are they and are they concentric/hub-centric spacers or just plain spacers ? Also, you did get the correct bolts to go with this setup too, correct ?
The fronts are H&R DR 15mm Trak+ Hubcentric Wheel spacers, purchased through Performance Wheel, with the recommended 40mm length bolts - carefully self installed.
Please keep us updated, good luck with the dealership.
audijim113
10-22-2004 08:04 PM
