Wheel mounting + balancing and TPMS
Few questions that I hope some people can answer.
1. What is the average price for mounting and balancing for wheels on our cars?
2. Does anyone know if putting on aftermarket wheels will require the transfer of the TPMS as well?
3. Can the wheels be removed or is the TPMS connected to them preventing removal?
4. Also, what if one does not want the TPMS anyway?
TIA
TIA
$20 - $35 per wheel.
You don't have to worry about TPMS hardware on a 2011 car. It has the newer system which reads thru the ABS system.
TIA
TIA
FatalBert- there are no TPMS sensors. it is done using the ABS wheel rate sensors, no TPMS sensors in wheels. as far as typical tire mounting rates, contact your local installer for quote.
Bruce
Bruce
Is this also true for 2010 models? I will eventually change my tires with all seasons. Another question is I know the stock tires came filled with nitro air....I'm probably not going to get the new tires filled with any nitro....will it be a big difference in performance?
Appreciate the info, thanks.
Bruce
It's easy to identify traditional TPMS vs. the ABS-based system. Cars with the traditional system and in-wheel sensors will have METAL valve stems. Cars with the newer system (sensor-less) will have RUBBER valve stems
S4inSFBay
Q7 MK 1 Discussion
10
07-01-2013 11:39 AM
jaksak
01-22-2011 05:50 PM
moto-one
Audi allroad
04-23-2003 07:49 AM
