When you click on links to various merchants on this site and make a purchase, this can result in this site earning a commission. Affiliate programs and affiliations include, but are not limited to, the eBay Partner Network.
Hello new to the forum and I could use some assistance. I lowered my S4 on H&R VTF springs and tried to set the new ride height with OBD11. Long story short after following the sequence I could only get the left front to set and the other 3 corners stated "function not available". I set everything back as it was and now I get a "control position not adapted" error. I've went back thru the steps to no avail. I've even order a vcds from Ross to tru to fix. If anyone has any insight it would be greatly appreciated.
Elementary comment here but, did you check all the wiring, plugs, leveling arms (not to be confused with control arms)? If and when, you've exhausted your findings, changes, how about putting everything back to stock to make sure sensors are properly working. Hopefully others will chime in to give their expertise. As my B9 is still on stock suspension/ride height (19s).
