21 S4 minor problems
- The Active Lane Keep Assist is gone - checked settings and it shows options for early or late warning and vibrates but there are no little lines on the dash that are either white when it's not active or green when active)
- Using the key fob or touching the door to lock no longer folds the mirrors. I have tried on all mirror settings so I don't think I am doing anything wrong. I can still manually fold the mirrors (as I need to so I can park in my tight garage).
I am just wondering if anyone else has had these problems?
While not urgent I am concerned the locked car with mirrors open may make it appear the car is not locked. I know I can fold them manually but inevitably I will sometimes forget.
TIA
Why would open mirrors be a red flag that the car is unlocked? My ‘21 is a Premium trim, so I don’t have those features to begin with, but it never occurred to me that unfolded mirrors would signal to crooks that the car is unlocked. 95% of cars on the road don’t have this feature. While I don’t miss folding mirror, I would have liked side mirrors to tilt down when you put the car in reverse.
Fold Mirrors on Lock is in the MMI--check in Vehicle/Settings/Central Locking if it's like mine.
I expect the Premium has the mirror tilt function. Try this: Keep your mirror selection wheel on the passenger mirror, and when the car is in Reverse, adjust the tilt to your liking. When you go to Drive it will return to the nominal setting.
I’ll try the tilt down feature. Thanks for the tip!
@Bada Bing - post a picture of the driver side mirror control; if there are two positions below the **** they are likely power folding and heatind; if only one then likely heating only.
https://www.audiworld.com/forums/s4-.../#post25495974
Order guide here explicitly mentions "heated power exterior mirrors (manual folding) for the Premium trim. Mirror tilt on reverse usually comes only if you have memory seats, as the memory function is used to record the mirror position for normal operation so the car knows where to reset the mirror after tilting.
waninae39
Q5/SQ5 MKI (8R) Discussion
11
06-15-2016 04:07 AM
