"Chemical Decarbonization"
#11
Got mine from Pep boys - made by "Excite" a "Winner technologies" company
Looks like washer fluid pipe and has rubber ends and a plastic "flow adjustment" clamp in the middle.
Winner Technologies
Sharon, PA 16146
Damned if I can see the product listed on their website any more though...
You could easily make your own for a fraction of the cost.
Best wishes,
Ram<ul><li><a href="http://www.winner-intl.com/automotive/default.htm">http://www.winner-intl.com/automotive/default.htm</a</li></ul>
Winner Technologies
Sharon, PA 16146
Best wishes,
#12
I am a little scared of doing this - hydrolock anyone?
How Many Mechanics Use SEA FOAM
In Tune-Up of 4 Cycle Gasoline Carbureted or Fuel Injected Engines
Autos, Trucks, and Tractors
1. With engine warm, slowly pour 1/3 to 1/2 pint through carburetor or throttle body throat. (If vehicle is port injected slowly pour SEA FOAM through direct manifold vacuum line that will feed all cylinders, possible sources are P.C.V. valve or brake booster line.) This will pull SEA FOAM down on top of the pistons and to the back of the intake valves to dissolve carbon. Turn ignition off. Restart engine after 5 minutes. If severe carbon build up is apparent, use more Sea Foam as previously directed. Make sure exhaust is well ventilated when using Sea Foam in these various ways as fumes will be extreme for a short time.
2. Pour 1/3 to 1/2 pint into oil crank case to clean rings, lifters, dirty parts and remove moisture.
3. Pour 1/3 to 1 full pint into fuel tank to clean injectors, carburetor jets, fuel lines and remove moisture.
4. Immediate Results: Smoother idle, increased R.P.M.'s better throttle response and improved performance. See label on can for detailed results for use in each area.
quickaudi:STFA
04-24-2006 08:03 AM
silver rain
07-23-2004 01:44 PM
VA_Esfour
07-21-2004 02:51 PM
18, audi, auto, decarbonization, decarbonizing, detailer, engine, exhaust, fl, fort, griffin, intake, lauderdale, terry, water
