*Edit* Auto Question: Is it okay to use gasket maker or sealant instead of gasket on water pump?
Instead of buying new water pump gasket, can you just use a sealant in the gasket's place? I don't see why not. If the sealant is able to withstand the fluids (e.g. coolant) it comes in contact with and high temps, won't a sealant be just as effective as a gasket? I figure the sealant would expand as it dries and prevent any leaks from water pump Just curious because I'll be doing my timing belt/water pump in the next 6 months.
meaning every bit of old coolant is drained out, and not collecting on the bottom sealing surface of the pump mating surface, then yes, there's a good chance RTV will work. However, I'm not quite sure why you would want to do this.
came with the water pump so I did this. Just wanted to make sure this would be okay for a long-term solution when I do the S4.
Zamore
02-19-2005 01:17 PM
Raoul
05-30-2004 06:02 AM
