02 S4 Xenon or Bi-Xenon and where do i get just the bulbs?
Old 09-25-2008, 07:48 AM
Member
TPM2002's Avatar
Default 02 S4 Xenon or Bi-Xenon and where do i get just the bulbs?
They have 124,000 miles on them and aren't that bright anymore. The one on the right is starting to turn a little bit of a different color. I thought if i replaced the bulbs that it might fix the issues. Anything else it might be? The lenses aren't in bad shape at all.
Old 09-25-2008, 07:54 AM
Wrinkledpants's Avatar
Default Probably not. Those bulbs definitely need to be replaced. Check in eBay for D2S bulbs
or try froogle.com. Mine were horrible at 90k, I can't imagine how dim they would be with that high of mileage.
Old 09-25-2008, 07:55 AM
AudiSportB5S4's Avatar
that or, ECSTuning sells them. ZiZa D2S. I had them, they were great. I got 6K nice color
Old 09-25-2008, 07:56 AM
Member
TPM2002's Avatar
Thanks. They are very dim. Are the bulbs easy to put in and how much is a good price?
Old 09-25-2008, 08:01 AM
Member
TPM2002's Avatar
Whats the stock color? 5000k?
Old 09-25-2008, 08:03 AM
3800K I believe
Old 09-25-2008, 08:13 AM
Member
TPM2002's Avatar
Default Does this look right?
http://www.theretrofitsource.com/content/s_7.jpg
Easy to put in? Cost?
Old 09-25-2008, 08:34 AM
Default yes thats right. they are extremely easy to put in, do THIS.....
1.first, open hood...
2.take off the cover with the lightning bolt on it warning you of how fcked you can get by the powa of xenon lol.
3.unplug the bulb from the harness, dont overthink this step, its easy.
4.your bulb should be in there not plugged in, but still secured by a clip, get that clip off, its easy as well you push down so it slides out of some locking thing you'll understand when you're in there...
5.reinstall new bulb, do the clip! THEN, plug it in. DO NOT try to plug the bulb in and wiggle the clip over it you will want to kill yourself.
6. cover back on with lightning bolt
7. on to the next side
Old 09-25-2008, 08:42 AM
Member
TPM2002's Avatar
Default Thank you! Very helpful! Dealer quoted me $450 for the pair of OEM bulbs HELP...
I want the OEM bulbs, nothing blue or fancy. The stock 3800k i guess they are. I don't do e-bay and need a trusted online retailer to order from. Ideas?
Old 09-25-2008, 08:44 AM
Default click the link i provide, buy these, 4200 K is "stock replacement"
i highly recommend these, they were great for me, i also dont like ebay
they are 170 for the pair. ECS is great too...
you're welcome man no problem<ul><li><a href="http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engine=2.7T&amp;mod el=B5%20S4&amp;submodel=&amp;category=Lighting&amp ;subcategory=Headlights">http://www.ecstuning.com/stage/edpd/pagebuild_v2.cgi?make=Audi&amp;engin
Quick Reply: 02 S4 Xenon or Bi-Xenon and where do i get just the bulbs?
