034 3.0L with GT28 ?
#12
#13
I am interested to see the breather setup once complete. I am curious how many premature turbo failures are caused by inferior stock breather systems causing crank case pressure to blow out turbo seals.
#17
#18
Guru: What other costs are involved with the girdle? And dont you lose some of the trans bolts with the girdle? I was thinking about using the girdle, just not sure if i want to lose some trans bolts or if its even worth it.
#19
Machining labor, and line boring the block. A plus is to balance the rotating assembly after with clutch an crank pulley.
Machine shop spent more than 20 hours on my shortblock assembly to make it perfect...
