1 BAR = How Many PSI? And at what does stock S4 max?
Mine's topping out at 7.5 psi and am looking for reference points. Thinking it's EGTs since there seem to be no leaks.
Thanks.
Thanks.
A Bar is a metric measurement standard defined as exactly 100,000 N/m^2, and was created for it's ease of use in calculations.
An Atm is defined as the atmospheric pressure at sea level at 0 deg centigrade temperature.
is this a peak/hold on your gauge, or are you logging via VAG? Use at least 3rd gear to test max sustained boost, btw.
The Chart:
1 atm = 14.6959487755134 PSI
1 atm = 1.0332 kg/cm<sup>2</sup>
1 kg/cm<sup>2</sup> = 14.223 PSI
1 kg/cm<sup>2</sup> = 0.98067 bar
1 kg/cm<sup>2</sup> = 0.9678 atm
1 bar = 14.5037737730209 PSI
1 bar = 29.54 in Hg
1 bar = 0.986923266716013 atm
1 bar = 1.01972 kg/cm<sup>2</sup>
1 in Hg = 0.4912 PSI
1 in Hg = 0.03385 bar
1 PSI = 0.0689475 bar
1 PSI = 2.036 in Hg
1 PSI = 0.0680459 atm
1 PSI = 0.070308 kg/cm<sup>2</sup>
The Chart:
1 bar = 29.54 in Hg
1 PSI = 2.036 in Hg
