17693 p1555 35-10 means overboost from what I can tell. Why is that a problem?
I pressure tested last week. All appeared to be fine. It sounded like my car
was gargling from under the engine, but someone told me that was normal.
In fact, I believe Josh told me that.
Gee. That's weird. When I stfa, I saw quite a few peeps with the same code. They didn't have Revo
No one has revo, man.
I did just throw down a 5.0 fats after turning my mbs down 4 lbs. I can't really complain.
If your actual boost is controlled by an MBC that is not set too high, should be fine. The code
would then just be an annoyance, but have no real meaning. A check of your actual boost levels using your VAG is still a worthy thing to look at IMO.
Bruce
Bruce
I actually got this code when you and I did some logging a while back.
I've turned my boost down a few notches and plan to retune once I get an exhaust.
Thanks,
Thanks,
Kiril Gitlin
05-13-2015 04:18 PM
tuneda4
09-17-2006 06:09 PM
aubiexx
02-06-2004 08:30 AM
