2000 S4...39K Miles...Timing Belt Failed...Man oh man
#23
I agree. It's not the belt that goes bad as I'm sure you know. In theory , if the belt is still supple and undamaged, you can reuse it. Not that I would.
The trick is to get a new GNK water pump. That way you don't have to worry about the pump prematurely going bad. They have a larger bearing than the OE pump, so they last longer. Also, the timing belt *absolutely has to be tensioned properly*( not too tight or too loose), or it will make all the bearings fail that are driven by the belt.. Don't expect the dealer to do it right either....
#25
I'm at home now, but at work I have it. Call me tomorrow Lance.
It's the same pump that the 2.8 uses. Whatever you do, make sure they tension the belt correctly, as this is key to going the 105k ;-)
#26
I can see how it might damage the serpentine belt that runs to the alternator, power-steering pump, etc. but how can a belt that is spinning the camshafts be damaged by the water pump?
(Please forgive me if this seems like a stupid question)
Steve
Steve
#29
The water pump is powered by the smooth backside of the timing belt, not the serpentine belt that drives the alternator, fan, PS pump, AC, etc.
If the water pump pulley(or any pulley) locks up due to bearing failure, the back of the timing belt starts to slide over the locked pulley causing friction and excessive heat. This causes the belt to melt and stretch and jump a few teeth or worse yet, even break.
If this happens early in an engines life, it is usually due to the belt not being properly tensioned.
ray@desenacpa.com
08-11-2010 09:37 AM
ttook
12
10-29-2005 01:06 AM
Suzanne
12-02-2002 07:57 AM
Negative459
08-17-2002 09:35 AM
