2000 S4 tip. ECU CODE HELP
Hello guys, I am a new S4 owner, I recently purchased a 2000 S4 Tip. 135k miles, one owner in pretty good condition. My CE light came one and EPC . Well, I went to Autozone, and had them pull ecu code's.
I am getting 2 codes :
1.P0741- the pcm has determined that the voltage signal from the torque converter clutch indicates inadequate performance or a "stuck off " condtion
- That seems very wierd,since the car runs fine (just can use a tune up )tranny does not slip at ALL, and once in a while a get a 2-1 downshift thats a tiny bit noticable.
2. P1633 - KAM Voltage to low.
- I have no idea what this can mean, any ideas?
Like I said car runs perfectly, just a bit sluggish on the bottom end (needs tune up ) I am also guessing the tranny has not been flushed in for ever.
Just incase you are wondering, the car is bone stock. Seems to be in very good condition.
disconnecting the battey to clear out the p0741 code.
Just a guess. Good luck!:-)
Oh-forgot. When the TCC goes many drivers would never even notice if it weren't for the light. Some would even argue that the car is actually smoother without a converter clutch.
you think , I may need a torque converter? The car does not slip at all, drives perfect even if driven hard.
Torque converters allow you to have the trans in gear, yet be at a complete stop without stalling the engine. It's fluid coupling that always slips a little. A clutch was added to modern converters to lock it up completely given the proper circumstances, avoiding that gas guzzling fluid shear and reducing fluid temps.
dabbdc@yahoo.com
12-02-2008 04:40 PM
Nappy Headed Ho
04-13-2007 11:46 AM
Justin:NorCal
10-11-2005 05:54 AM
OverSpun
VAG-COM Discussion
02-20-2004 10:27 AM
Allroady DungBeetle
08-30-2003 07:01 AM
