220hp issue (stage II), now 240hp S4, logs included, thoughts?
#11
I had the MBC and TCD in. I was told it would help if I were to up the timing and put in race gas. I added the n75 back in because my turbo started to get louder and I wanted to be sure I wasn't overboosting the car. That being said, I always had the MBC set fairly conservatively.
It may come down to removing things and then putting them back on, one at a time, updating the tune, and so on.
Aside from having the TCD and MBC, does anyone see anything in the graphs I've posted that seems out of the ordinary?
#14
VAST recommends that I just use the MBC with the TCD as well.
I am replacing the driver's rear window regulator tonight (just replaced the other one due to the plastic disk failure a few weeks ago). I will take care of the N75 while I am at it.
#20
two unimpressive fans on the intercoolers (the kind you'd find used in a home garage to circulate air, about two and a half feet tall, low rpm) and a decent one on the radiator (snail type fan).
