which is the 4th cylinder? passanger or driver side? Thanks
If you think you've got a back coilpack, or if you pulled a code for a bad coilpack, swap the coilpack to another cyl. If the code doesn't move, it's not the coilpack. If it does move -- bingo!
If it doesn't move, then swap the plug itself to another cyl and see if the code moves then.
Good luck.
Good luck.
the car idles drops a little and I hear ticking sound. The car did have a misfire on 4th cylinder. Just changed plugs also. Didn't help problem. I guess I will move the coil pack to the opposite side of engine and see what happens. If ticking goes to right cylinder bank, then that is it. I guess.
Number54
07-10-2008 11:06 AM
teedoff00
02-23-2008 04:52 PM
