6spd: Transmission shifting problems.... Need advice
Anyways, here is my problem. When I go to crack the car up in the morning, I will try to put my car in gear, and in wont go in. I have to turn the car off, then put it in gear, however when I turn the car on with the clutch all the way down, the car moves in slightly in reverse. The next similiar issue is the fact that when im driving, and take it out of gear, I have problems getting it back in gear, I kinda have to push the clutch in and out and couple of times before it lets me put it in gear. NOte: This happen about 50 percent of the times. Please if any one can help thanks.
the clutch still grips great. The problem got really bad when change out my brakes, and mix my old brake fluid with ATE Super Blue Brake Fluid. I dont know if thats the problem. I am 94000 est miles on the car.
Note: It shifts good going from 1st to 2nd, 2nd to 3rd, 4th to 5th, 5th to 6th. However, it acts up when I take it out of gear to slow down at a red light or something, and when I go to put it back in gear it wont go it easly
chances are the clutch and flywheel are still spinning too fast for the 1st gear syncro, when you take it out of gear how far from the light are you do you have to brake firmly but not harshly?
Mr Paul [T-28]
08-22-2008 10:06 AM
BigMouse
01-15-2006 03:39 PM
Absolute Santorin
02-27-2004 09:27 PM
