About to start my first timing belt replacement, wish me luck.
make sure is TDC (top dead center) and it stays there (use the bar and the pin) ..do you have the tools to take out the fan ?
so turn to the right to loosen - opposite of normal.....my fan was on there tigher than any fan in history after I got done cranking it to the left (counterclockwise)
you have to do that (put the 20Mn tension on the belt) and then tighten the cam sprokets i guess ..correct ?
i didn't do that and everything is fine.. i just made sure thatre was tension in the belt before i tighten the cam sprokets back up , having the cam lock BAR IN PLACE of course.
