abs codes
abs codes
i checked the forums and it looks like my abs ecu is going out. these are the codes and the only one i am concerned about is the connection between abs and instrument cluster. is this the abs ecu or something else. i am planning on sending ecu to module masters for repair but i am wondering if the second code is something else.
Address 01: Engine
Part No: 8D0 907 551 A
Component: 2.7l V6/5VT G 0003
Coding: 06611
Shop #: WSC 06325
1 Fault Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Part No: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Address 01: Engine
Coding: 06611
Shop #: WSC 06325
1 Fault Found:
1 Fault Found:
It's time for an ABS control module rebuild...
from Avalon Motorsports<ul><li><a href="http://www.avalonmotorsports.com/index.php?main_page=product_info&cPath=1_2_114 &products_id=240">http://www.avalonmotorsports.com/index.php?main_page=product_info&cPath=1_2_114 &products_id=240</a</li></ul>
JimR
11
08-05-2008 11:33 AM
