ABS/ESP Expert Help Needed...?
#11
Chris
When turning the wheel, did the value go positive to the right and negative to the left? Because mine is the opposite. And I will check for farthest values (+/-505). Mine Should read like -520 and +490.
And yes, you can read all WSS values via VAG. In Adv Meas Values (Where you read steering wheel angle above, there are 4 readings for each Wheel Speed Sensor).
Looks like I need an alignment, a used clock spring, and clean my WSS's...and see if that helps.
#13
Make sure that you can see the colored dot in the window of the clock spring. That is when the G85 is at 0. You have to manually turn the clock spring when it is off the steering column to do this. Make sure you can still see the colored dot after installation.
4Ring Jelly
Audi allroad
28
12-22-2008 01:32 PM
ryans4
17
05-17-2005 08:16 AM
