ABS Problem Help please - VAG Results inside...
Eariler on I posted my problem of the ABS light coming on and the parking brake light flashig at me. The problesm is NOT constant and goes on and off randomly (I don't know if something I do makes it come on or off)
The ABS works fine when the warning lights are NOT on, and I have no ABS when the lights ARE on.
So, I broke down and bought a VAG COM - Here is what it told me, and hopefully someone can offer a solution:
Address 01: Engine
Controller: 8D0 907 551 A
Component: 2.7l V6/5VT G 0003
Coding: 06611
Shop #: WSC 06325
1 Fault Found:
18014 - Rough Road/Engine Torque Signal from ABS: Electrical Malfunction
P1606 - 35-10 - - - Intermittent
Readiness: 0000 0000
Address 03: ABS Brakes
Controller: 8E0 614 111 A
Component: ABS/EDS 5.3 QUATTRO D10
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
01203 - Electrical Connection between ABS and Instrument Cluster
03-10 - No Signal - Intermittent
Thanks,
Mark
Address 01: Engine
Coding: 06611
Shop #: WSC 06325
1 Fault Found:
Coding: 0273004284
Shop #: BB 24334
1 Fault Found:
Thanks,
Mark
Ok, have the VAG hooked up to my car with the ABS light on. Can't connect at all with the ABS proble
S4Del
12-12-2003 04:23 PM
