ac leaking on floorboard, lots of H2O
whenever i run my ac, i get not a lil moisture, but an abnormally amount of water that leaks onto my floorboard, soaks the front and rear floorboard, that just shows how bad it leaks, its come to the point to where i dont ever try to use the AC. any suggestions?
That doesn't sound right. There is no way the a/c could cause that much water to condense in the car. Is it both sides of the car that are getting water in them or just one?
yea, its a lot oh water and its only on the driver passenger side. once the ac is on, its almost a constant drip
I know what that problem is.. Remove the side panels on both side of the console. You need to move the seats all the way back and tilt them up as far as they go. Remove the screws that holf the panel in place. After you remove the panels on both sides..look up under the dash towards the back you will see an orange tube ..clean it out. If you have an air hose blow into the top tube where the orange hose connects. Then repace and do the other side. They clog up and when they do the condesation fills up and starts to leak and spmetimes comes out of the vents...
SCL
01-12-2008 12:00 AM
NYCAudiFiend
07-23-2004 01:46 PM
speedracerrc
Audi 100 / A6 (C4 Platform)
08-04-2003 08:32 PM
ac, accord, audi, condensor, floorboard, floorboards, honda, leak, leaking, leaks, lots, passenger, passsenger, side, water
