Advice please - rear wheel bearing swap with SIR B90 - best way to get drive shaft out the way?
#13
It's been quite a while so I don't remember exactly. Taking that bolt out won't hurt your alignment, so if you need to, you may as well do the bracketracer method
#14
Kept it on my computer, but never see it on the forum when I search. Why not repost it, I think more people should see it
#15
Seems it can be left in situ when using SIR B90, those sensors are expensive and easily destroyed when attempting to remove, especially on an older car.
#18
I wasn't sure of that at the time, so I pulled it out. If you _can_ get the sensor out, clean up the rust and lightly antisieze it. It it doesn't come out easy, you'll likely destroy it by trying to force a rust frozen sensor out, leave it be!
Even if the sensor was somehow damaged by the puller or bearing, then you can just pound it out without having to worry about breaking it
dragon-ryder
13
04-05-2008 08:01 AM
Omega Supreme
07-11-2006 08:31 PM
SeeYa4
03-24-2003 04:51 AM
brierfr
03-23-2003 04:18 AM
