air intake leak detection methods
so far i've been using the pressure-test + soap water method.
i read about another method where a combustable gas is sprayed around suspected areas while the car is idling (with IAC unplugged). as far as the spray i've read "carb cleaner" & "brakleen". i thought seafoam spray may also be used.
it seems somewhat easier. any opinions? risks? cons?
any sprays not to use? any ingridients to watch out for?
any recommended sprays?
was able to find a leak with a smoke test when I first got the car, but it was a rather large one.
smoke testing seems safe; but i do not have a smoke machine, and it seems similar to pressure-testing which i have equipment for.
told us before...spray it around, when the idle increases, you've found the spot...just be careful not to start ur car on fire...I would have a fire extinguisher handy just in case...
Monster-S4
Southeast Discussion
03-02-2007 06:41 PM
