Airbag problem--I searched but nothing that could help--vag codes inside TIA
VAG-COM Version: Release 303.1
Control Module Part Number: 8D0 959 655 G
Component and/or Version: Airbag Front+Kopf 1002
Software Coding: 00304
Work Shop Code: WSC 06435
10 Faults Found:
01211 - Belt Tensioner Igniter: Rear Driver Side (N196)
32-10 - Resistance too High - Intermittent
01587 - Igniter 2 for Airbag: Drivers Side (N250)
00590 - Airbag Igniter 2: Passenger Side (N132)
01213 - Belt Tensioner Igniter: Rear Middle (N198)
36-10 - Open Circuit - Intermittent
01219 - Rear Airbag Igniter: Driver Side (N201)
01220 - Rear Airbag Igniter: Passenger Side (N202)
01578 - Airbag Deactivation Warning Lamp: Passenger Side (K145)
31-10 - Open or Short to Ground - Intermittent
01591 - Indicator Lamp for Airbag Off: Drivers Side (K144)
65535 - Internal Control Module Memory Error
00-10 - - - Intermittent
00656 - Seat Occupied Sensor: Passenger Side (G128)
I've replaced the driver side airbag since the shop *thought* that was the issue but no go with that. Any help will be greatly appericated.
Thanks,
10 Faults Found:
Thanks,
VA_Esfour
06-23-2006 05:59 AM
VA_Esfour
16
03-01-2006 01:54 PM
