All 4 of my O2 sensors are fried arent they? (fault codes inside)
Tuesday, 18 October 2005, 15:39:30
VAG-COM Version: Release 504.1-UD
Control Module Part Number: 8D0 907 551 M
Component and/or Version: 2.7l V6/5VT G 0002
Software Coding: 06711
Work Shop Code: WSC 06435
6 Faults Found:
17548 - Oxygen (Lambda) Sensor; B2 S2: Internal Resistance too High
P1140 - 35-00 - -
16520 - Oxygen (Lambda) Sensor B1 S2: Malfunction in Circuit
P0136 - 35-10 - - - Intermittent
17584 - Bank1: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1176 - 35-00 - -
17585 - Bank2: O2 (Lambda) Correction Behind Catalyst: Control Limit Reached
P1177 - 35-00 - -
16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
P0130 - 35-10 - - - Intermittent
16544 - Oxygen (Lambda) Sensor B2 S2: No Activity
P0160 - 35-10 - - - Intermittent
THAT WOULD EXPLAIN 14 MPG!!!!!! THANK GOODNESS
thanks in advance
6 Faults Found:
P1140 - 35-00 - -
P1176 - 35-00 - -
P1177 - 35-00 - -
thanks in advance
well, the rears failed months ago, but i never replaced them because i was told it was
unnecessary. just this past few weeks, ive been getting HORRIBLE gas mileage, and ive been running extremely rich. I checked my fault codes again, and now the two front sensors are bad too... just ordered the set of 4 from Vast.
BlackS4tt (Josh)
12
11-11-2005 04:29 AM
BlackS4tt (Josh)
VAG-COM Discussion
09-01-2005 07:33 PM
RMcQ
10
07-17-2003 07:14 AM
RMcQ
Audi allroad
07-17-2003 06:28 AM
