Another quick question - are people ordering new clamps with the 710N's?
I ordered new clamps with my Bailey's...does that count?
I don't like the crimp type clamps, you can't re-use them.
I switched to all resuable Oetiker clamps (Stepless Self Tensioning clamps).
They are right about 6 clamps...but you can use zip ties for the vacuum lines...
which means you only need the two clamps per BPV. But for $70, i'd just buy forges or bailey's.
After all, even though the 710's are better than stock, they are still the same mechanics (diaphram not a piston).
FWIW...
FWIW...
Yes. 9.5 mm Oetiker clamps for stock look.
You dont' need 6. You can reuse the 4 larger clamps, unless you mess them up in the removal process.
The Oetiker clamps you can get from the dealer or from <a href="http://www.mcmaster.com">McMaster-Carr</a>
Stepless Ear Hose Clamps
PN# 52545K42 pkg of 25 for $6.88
<img src="http://www.mcmaster.com/catalog/108/gfx/large/52545kp1l.gif">
Differences...
The Bosch 0-280-142-110 valve is used on Saab Viggens. Not sure about the rating, but I think that Saab runs around 1-1.4 bar boost. So I assume the valve is rated a little higher 1.6 - 2.0 bar. It has never been used by Audi and does not have an Audi p/n.
Bosch 0-280-142-114 is the revised TT valve - Audi pn is 06A-145-710N. It is rated to 1.6 bar.
